pic of work so far
fuzzeywiggler
Re: pic of work so far
OK here a set for you guys , my motor stand with my 1962 1000 100hp and my evenrude 1953 15 hp
Ok guys and gals let me know whay you think ???? John
Stand looks great.
Wheels are a huge bonus!
But O man Im shocked that your merc has a pull start on it, Have you ever tried it for kicks to see if its possible? Mabey you could pull half the plugs to get it started :D
Fuzzy
ne7800
John you get the camper wintrized yet? I just blew out the water lines on mine
ne7800
well i would have got mine done sooner but i just got the truck fixed 2 days ago :mad: ended up not being the starter (that i had rebuilt) it was a corroded ground wire from the battery to the block :eek: cost 45 cents to fix. But............. i alredy spent 40 on the starter rebuild (i trust my starter guy and he said it worked on a bench test but it was full of rust and needed a few parts)
jcsercsa
Domt that stink when that happens !!!Well you wont have to worrie about it for a while!!John
oops!
naw wait a minit......john are you telling us that you were so pizzed at your self for missing the 2 shots at the deer, that the only way you gould get one was to run it down with your truck? :D
glad no one was hurt. :)
those are all easy fixes....but ill look closer when i get to work
jcsercsa
HAHAHAHAHA yep i was so pizzed that i got in the truck and went Bah haain till i got one !!! hahahahah
Cool tell me what you think ??? I got pics comming of all the grinding i did today !! joHN
jcsercsa
Ok everyone Heres what i got done today !And man are you right oops that 220 grit sure does take it off fast !!! now i just got to find somemore 7inch 220 grit hook and look paper ran out today !! they didnt have any more at Harbor Freight ??? You can see the spots that i hit and it was gone in seconds !! lol
heres what the difference it made in the gelcoat !!
jcsercsa
Heres some pics of all the spiders i ground out !!and all the spiders around the bolt holes !!!
Then this next pic is of a repair that someone did before me , and he put silacone in the hole the gelcoated over it
then this last pic is of the dash with out the contact paper on it , it wasnt hard to get off , just took a wire wheel to it and it came right off !!
Ok let me know what you all think !!!! john
jcsercsa
Stand looks great.
Fuzzy
Hahaha yea right , I didt even try it the last time i was out and she didnt start, i am kind of afraid of it ,[i like my back the way it is lol] i got to fog her yet so i guess i will have to try it, I will let you know , wish me luck !!lol john
oops!
john........
for the gellcoat repairs you nreed to do.
take a foam backing pad........and sand the areas.
a grinder will make sharp edges.......sand it then make gell coat repairs......
ill give you more on this later, when i can
cheers bud
ward
jcsercsa
john........
cheers bud
ward
Ok will do,still think i need to start with 320 grit ,I seen that and tried to stay away from the corners, i do have to fix the edge on thar frist pic ,its not to bad!!John
ne7800
John hurry up! I want to see that bad boy painted :D
jcsercsa
Ohh Man i am back , My puter is fixed !!!!!!John
ne7800
welcome back! here comes the post padding :D:eek::D
ne7800
:D Naw i was just kidding I know you would never post pad :D
