jpate9
Thread starter- Joined
- Nov 7, 2007
- 7
This is my first post here and I don't know if this has been asked before. I have a 1971 Merc 500 thunderbolt, electric ignition. I just bought the boat a couple of months ago. I tried the engine out in neutral in a trash can of water. It seemd to run just fine. I could rev the engine at will. I tried burning off as much of the old gas as possible this way. I added 10 gallons of high octane gas with the 50:1 ratio of oil. Still ran great in neutral.
We took it out to the lake and it puttered around the no-wake zone. It seemd to sputter some but got us to the lake to open it up. When I finally gave it throttle in gear, it started to stall. I pulled back on the throttle and tried running in sputter-mode to burn of as much gas as I can. I tried the throttle again and it stalled completely. Then I had difficulty getting it to start again. It seemed like it was flooded.
After waiting a while. It started again and ran great in neutral. Each time I tried throttle in gear the cycle repeated. We took it to a certified mechanic and he changed the spark plugs which were fouled. We thought we had it fixed and went back to the lake. The cycle repeated once again. The mechanic suggested rebuilding the carbs and gave us a very scary quote.
I've looked at the oldmercs website and saw that the rebuild kits are pretty reasonable so I think I might try doing that myself. It would be a nice project.
Today a saw a thread that mentioned "timing is synched to carb/throttle advance" and was wondering if this may be important.
My first question: Is there something different with the throttle / timing / fuel when an outboard is in neatral as opposed to in gear? The control for this boat has a separate lever for trhottle when in neutral.
Next Question: Could this be something else? I am going to try taking out the spark plugs and see if there is any resistance in the lower unit when I am in gear.
Please Help and Thanks in Advance.
