Re: machine shop recomendations
hello,
one area were most engines run same specs is with conventional engine ring gaps. .007 - .017 is pretty standard. 4 or 2 stroke. .021 is too big, but for a worn out engine, snugged up else where, too it will run ok. but u will note if 4 stroke oil gets dirty faster.
most fresh engines shoot for around .010 - 012. u do see the larger gaps .015 - .021 + on engines where the combustion mixture is additionally compressed such as with nitrous and or supercharging
due to addl heat produced.
so shoot for .010 - 012 for normal use. if WOT lots or most of the time, i would opt then for .012 - 015. ring needs to be perpendicular to bore to measure. most engine builders seat it with the piston.
a sometimes WOT engine i would be ok with .008 to .011 or so. buzz it, for less tha 30 - 45 sec at WOT and the throttle back to let it all cool down some. maybe 15- 20 secs is better. cavet emptor~
if they get too tight or u butt gaps hard, u can break them in two.
be sure the rings u use are faced correctly for ur application.
be sure to break the 4 sharp sides of each gap end [2 per ring] at the ring split. std ops for good engine building technique. use a small file.
and for my bet, never install rings by hand. always use a ring expander.
sorry to hear u have to do the work over...
regards
lakester
