JJB
Thread starter- Joined
- Dec 28, 2006
- 274
2000 175 fresh rebuilt 2 hrs on it ! has vro pump! I am having a problem getting my 175 to idle smooth at the 600 to 1200 rpm range it did run good above that .I have cleaned and rebuilt the carbs set floats to factory spec. Set the timming and Throttle pick up to factory spec . Did a commpression check and it is good and even in all cyl . I connected a remote gas tank , new primer bulb and gas lines to the fuel connection on the engine to rule out my tank and still rough at idle . I notice if I keep pumping the ball nice and slow and it gets better . My question is that the engine was sitting for 6-7 months and only started on a stand for 5 min a week . It was using double oil during those months and still is . That why I rebuilt the carbs and they did have build up in them and it did help with the upper rpms and idle . I was wondering if the fuel pump needle and seat has build up on it also ? or maybe the fuel pump is starting to go bad ? It looks like it is the original vro pump unit . Sometimes I hear a click in the vro unit when I prime the carbs .
Thanks for your input .
