96 130HP Evinrude Gearbox
david565L
Yesterday I Noticed Abit Of Gear Box Oil Leaking Out From Bottom of Leg Today Is Still Doing it. What Could This Be
Took Boat Out 1 Week Ago all Was Good That Was Last Time Motor Has Been On.
HighTrim
Re: 96 130HP Evinrude Gearbox
Are you sure it is lower unit oil? Read over this thread, it may help. It is very likely that what you are seeing is unburnt fuel/oil mix, which is very common.
http://forums.iboats.com/showthread.php?t=207285
If you determine that it is in fact lower unit oil, you will need to pressure test to determine where the leak is. Open up the drain screw and see if the first bit of oil exits is milky white, indicating water intrusion. Is the oil level low?
david565L
yeh it is coming out a milky colour when i open screew.
HighTrim
The number 1 spot for water intrusion into the lower unit is the drain and vent screw gaskets. They should be changed every time the screws are out. I would try changing them, along with a good synthetic oil, running it, then checking it again for water. If that doesnt solve the problem, you will need to pressure test it, or simply change out all the seals.
To pressure/vacuum test a lower unit:
a) drain the gear oil
b) use an appropriate adapter with a gauge tee'd in to apply pressure or vacuum. No more than 15 psig for pressure. You can use a bicycle pump or any other compressed air source for pressure. For vacuum, you need a vacuum pump.
c) LU should retain some pressure or vacuum for 45 minutes minimum.
d) If pressure doesn't hold, submerge LU in water to find leak source, or spray it with soapy water [possibilities: drive shaft seal, prop shaft seal(s) (usually two), shift shaft seal and the fill/drain screw washers.]
e) replace offending seal(s) as required.
Could you post pics ??
david565L
no cannot post pics.
the last 3 days have been in excess of 40 degress celcius could this have anything to do with it?
HighTrim
One of the reasons I was first leaning towards unburnt fuel/oil mix. It is VERY common, and very often mistaken for lower unit oil, as the link that I posted explains. Check the level of the lower unit oil, if it is still full, you will know it is not that. However, the milky white oil still tells you that you have water intrusion into the lower unit anyways that needs to be looked at.
HighTrim
When filling, the gearcase is full when fluid exits out the vent screw hole. Is this boat new to you? When was the lower unit oil last changed? You should change it every fall, along with new vent and drain screw gaskets.
david565L
gear oil was changed about 1 month ago not sure if gaskets were changed
