I have a 96 200hp Johnson carb motor on a 20' Gulf Coast that has about 225 hours on a new power head. WOT is about 5300 rpm with a shallow water cup in the prop. A couple of weeks ago, it would only run about 4600-4800 rpm's and I noticed it had lost power. I changed the spin on fuel filter, plugs and put some 92 octane gas in it (mixed with what was in the tank) and it went back to 5300rpm's. Today, I was running WOT and it dropped to 4800 and then to 4500 and then to 4300 and you could feel and hear the lose of power. All the sudden it got a burst of energy (lol) and hit 5300 rpm,s again. You can feel it surging at times like it has a plugged filter or bad gas. When I got home today, I pulled the spin on filter off and poured it in a glass and let it set, to see if I had any water in the fuel and no water. I changed the in line plastic filter under the cowling and it was easy to blow through with no resistance. I changed it today anyway. Can a fuel pump be going bad or be weak? Is the fuel pump a diaphragm style pump? Aren't they usually good or bad? It seems to be fuel related. Any suggestions or thoughts??????
