HyperFox
Thread starter- Joined
- Dec 31, 2007
- 78
So as some may know, Ive acquired a boat motor and trailer from a friend of mine he described some problems he's had with the boat through an email.
First thing he mentioned was that the starter grinds when activated. I inspected the starter and noticed it was too far away from the flywheel. Simple adjustment really and I think I got that fixed up.
Other issues were wiring. A lot of it was cracked from age, so I replaced it all with fresh wiring. Fires on a boat are a sailors nightmare, right?
The third problem he mentioned is the one I'm stuck on. He claims while cruising at WOT, the engine "slams". He described it like a bunny hop. At less throttle the boat doesn't seem to have the issue.
Im not terribly sure how to approach this in the winter. I beleve perhaps the mounts on the outboard arent tight enough and as the boat skips, the engine flexes on the mount and might cause this. Or perhaps the starter gear pops back up and bogs out the engine as it hops across the water? Is there any quirk about these motors im missing?
