reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I was talking to someone today who works with fiberglass and boats for a living. I was told to be careful about using polyester resin to water proof or to laminate anything that will contact aluminum? I was told that it would cause corrosion anyplace where it may come in contact with the aluminum hull?
Has anyone heard this before? If it's true, does it mean that its only corrosive while it's curing or after the fact as well? I have seen people laminate several layers of plywood to make up the transom reinforcement wood on aluminum boats and never really gave it any thought. I used epoxy on all of mine, but only because I already had it here and have a good source for it.
I have also used Bondo on aluminum body panels with no problems, but I have always prepped the panel with an etching primer first.
I also heard the same thing from a body man once, but never gave it much thought or put much weight on his opinion, this guy repairs boat hulls for a living and has an engineering degree. What has me puzzled is that some polyester resins use aluminum as a reinforcement, although not for the boat industry, they do exist.
What I am thinking is that if polyester resin or filler was used on aluminum without the proper prep work, it may allow water to penetrate the joint of patch, thus causing corrosion?
Does polyester resin corrode aluminum? Has anyone ever heard of this before?
