I have this old motor that I am trying to get going this winter. I did some things last fall to it and here is what I know: compression is good, spark is good, impellor new, carb kit installed, still runs like crap. It will start and run but not idle well also when you give it more throttle it bogs out. Usuall after it runs for a few mintes it takes some time before it will start again. I did bend the sharp end of the lean/rich needle slightly when installing the carb kit, but I did my best to straighten it back out. What I did was I just curled the tip over, is this something to be concerned about at this point? What can I do to make this thing run good? Since the compression is good I can't imagine it can be anything too serious. Thanks for the help, any ideas would be appreciated
