Towing Charges
PAkev
I have a Chev Silverado 2500 w/ Duramax Diesel and have been offered an opportunity to do some towing for a local dealer. It involves a trip to South Jersey from PA once a week (about 250 round miles) Jan. through March and a few local shows within 50 miles of the dealership. Since I won't be doing any boating until April I'm thinking of accepting the offer for some supplemental income.
The first and most obvious is that I would have to cover my fuel expense. The other which I'm not sure is what is a fair cost to impose for wear and tear to my truck and my personal time. So far I've came up with learning some E bay haulers and brokers command upwards of $2.00 per loaded mile. Also, I presume there is a weight factor to go by since it's a lot more efficient to tow a 14 ft tinny down the highway than a 26 ft cabin cruiser.
I want to be fair to myself and the dealer and realize it's a lot harder to request more money after agreeing to a price if I should learn that I'm only working close to breaking even.
Helpful advice appreciated.
blouderback
Re: Towing Charges
Since you'll be doing this for hire, you probably need a CDL. As far as a per mile charge, I think you'll have to give the dealer several price levels, one for each "class" (or weight) of boat, rather than a per mile / per pound rate. I think that'll be easier. Maybe $2/mile for anything up to 3000lbs, $4/mile for 3001-6000lbs, $6/mile for 6001-10000lbs, or something like that.
Re: Towing Charges
you also need to check on the IRS, deductions for business vehicle use. the taxes to be paid on the income, plus the social security. i'm sure he is not going to be paying you cash, and he's going to claim your fee as a cost of business.
External Combustion
Re: Towing Charges
You will also need commercial insurance as I know most companies will not cover you if you have an accident hauling a commercial load. The WILL find out. The cost of commercial insurance is a real eye opener :eek: and you will need compensated for it. You also will have to do the logbook thing, medical card, stop at most DOT stops etc.
It can be a good thing, just make sure you cover your cost.
Gary H NC
Re: Towing Charges
No CDL required,BUT you will need a US DOT number and the vehicle must be registered as a "for hire" vehicle,different license plates and all.Plus Insurance.
You could fly under the radar and not do any of the legal stuff but keep your fingers crossed nothing happens or you don't get pulled over by a DOT cop.
A CDL is only required for combination vehicles over 26001 pounds unless it has air brakes.
No log book needed inside a 250 mile radius..
Re: Towing Charges
Ayuh,........ Bob's #s are a Good start,......
And,......
Make sure you get paid for the Hours spent on Both ends.......
bjcsc
Re: Towing Charges
No CDL required,...
Careful, CDLs don't have anything to do with brakes whatsoever. If you have a CDL and want to drive a vehicle with air brakes in excess of 26000lbs, or haul a trailer rated for more than 10,000lbs that is equipped with air brakes you must have passed the air brake portion of the test. If you failed the air brake portion, you will have an air brake restriction. If you pull a trailer that is rated to tow more than 10,000lbs (notice that it is rated to tow, not what you're carrying, i.e. if your trailer is rated for 10001lbs you need a CDL regardless of how much you're carrying). This applies to any towing as part of a business. There are exemptions for personal hauling, but they vary from state to state. PAkev: do your homework before you commit - PA is one of the states that checks...
bjcsc
Re: Towing Charges
And since this has come up a couple of times recently, here's a link to the FMCSA's Registration and Licensing. This is not a commercial site per se, and it is important so maybe the link can stand...
Gary H NC
Re: Towing Charges
What i was saying with the air brakes is you must have a CDL if its a commercial vehicle.We have guys at work that pull the car hauler 40 ft trailers with just a regular license.Electric brakes and a dually pick up though.
The laws have changed a lot since i got my class A as it was called back in 1981.State to state laws vary on the weights and all of that.
Call the PA DOT and ask what you need PAkev..;)
Re: Towing Charges
Call the PA DOT and ask what you need PAkev... that's the best advice given.
jeeperman
Re: Towing Charges
Before you get too far into this you might want to work it from the other end.
i.e. ask the dealer what his going rate is for the others he has towing for him.
Sounds like he wants you to fetch boats from the manufacturer or to go to and from boat shows?
He might have others that are willing and already doing it for far less than what you want to even consider.
