I bought a boat with an incomplete (carbs, cylinder heads are missing) Johnson V4 90HP 1981 outboard. THe tilt & trim is intack - it has a two wire (blue & green) motor, which I suspect is shot. Is one wire for +ve up & the other for +ve down and the -ve provided through the metal motor housing? I have applied +ve 12 volts to one wire then the other with -ve 12 volts to the motor body - should this turn the motor?
Thanks
Thanks
