Drive removal
kmongar
Hello,
How do you guys support the drive for removal and re-installation? Mine has a swim platform right above it.
1995 VP 5.0FL, SX Cobra
Haut Medoc
Re: Drive removal
Brute strength......;)
It does help if you raise or lower your trailer so the tip of the skeg is just touching the ground......:)​
mcleaves
Re: Drive removal
Yup, just lift it and slide it off/on. Once it's on the studs you can get a nut on a couple threads.
According to the manuals you can thread an eye bolt into the dipstick hole and lift with a mechanical device, but that obviously doesn't work for most of the boats out there since most have swim platforms
M
MikDee
Banned
Re: Drive removal
Gorilla It! Eat your Wheaties that morning,,, lol,,, actually it's mostly aluminum, but don't let that fool you it's still a bit heavy, but not as bad as it looks. One guy can usually get it off, & on, and drop it on the tailgate if need be.
jmills224
Re: Drive removal
I don't have the same drive as you but....I lower the sterndrive onto a piece of plywood and once unbolted slide it out while another person or a rope tied to the ski rope eye keeps it from tipping. It goes on the opposite way;).
johnbo
Re: Drive removal
There is a drawing and/or a picture of a setup that someone constructed out of 2x4's to support the drive. It was at least two years ago, because that is when I found it and built it.
Basically, you construct a set of 2x4 runners that support the horizontal fins (right below where the rams mount). These runners are about 3-4 foot long. Supporting this is a framework of 2x4's, that is custom cut to the height that you need with everything leveled out.
Works like a charm. Unbolt everything with the support under the drive, yank it back, catch the driveshaft before it falls out, and you are home free. Takes about 15 minutes to get it out. About the same or less to go back in.
Find the article, as it has a couple of fine points about open ends on the frame that I don't remember.
Later,
johnbo
JustJason
Re: Drive removal
if your not feeling super strong... swim platforms make things a pain... literally. they make special jacks... however for the casual user they are not worth it. depending on your access it may be worth your while to make something you can use in conjunction with an regular hydraulic auto jack. just remember when you go to put it back on, as heavy as it is it should slide on like butter. you should get an alignment bar if you don't already own one. you should check your alignment every time the drive comes off.
ziggy
Re: Drive removal
i've only removed my drive once, never put one back. so i ain't perticularly expereinced. but i made me a drive stand. when i took it off, i jacked up the trailer and adj. the trim on the drive till they were nice and level then pulled the drive. came off nice and smooth. hope to do the same going back on....
i've seen other guys stands they make, look better than mine. but so far mine has worked for me.....
JustJason
Re: Drive removal
ahhh... the orange book... i have a few of those kicking around
Lou C
Re: Drive removal
I just built something similar, but out of 2x6s, and mounted adjustible casters under it so I can adjust the height of it right up to the drive.
