Motor only runs whith choke on
mobytodd
1985 evinrude 40hp. I have cleaned the carbs ran, new fuel lines, cleaned the fuel pump... I am at a loss as what to do except rebuild the carbs and rebuild the fuel pump. any ideas guys?
Re: Motor only runs whith choke on
you've got it. right on track.
Evinrude Boater
Isn't he getting too much air in a loose connection, thus choking reduces the air coming through the venturi?
Did the motor run properly before working on the fuel system?
agree check for leaks, no since in only rebuilding one, how do you know which is bad. if they've never been done, overdue.
mobytodd
No the boat didnt run before. I am trouble shooting the thing right now. I think I am gonna check for loose hoses and start there. I will keep this thread open incase it is not that. Thanks.
F_R
Almost certainly dirty carbs, especially the high speed orfice jet in the bottom of the carb bowls. Those are right down there where fuel lays and turns to gum. Result is you have to keep choking it. A very common problem.
jay_merrill
Carb rebuild couldn't hurt and is a good idea if the motor is new to you, since you don't know when it was run last. If you rebuild them and you still have the problem, try smearing some grease on the external portion of the throttle butterfly shaft wher it meets the carb housing - there is sometimes wear in this area, which will cause the carb to suck air in. The grease may block that temporarily and aid in troubleshooting, but it isn't a long term fix.
samo_ott
If it only runs with the choke on, then it is not getting enough fuel in a normal situation and is probably the low speed side of the carbs. So I concur, check for air leaks and then rebuild em.
Evinrude Boater
You might see fuel leaking out the side of the carb at one of the plugs or other holes or the gasket at the intake manifold may be faulty.
georgiaboy
why does'nt he do a decarb if he can keep it running-wouldn't that get the gum out of the carbs without a rebuild? Just wondering.
HighTrim
No, a decarb does not take the place of a carb rebuild.
Mobytodd, see the FAQ for the decarb instructions.
samo_ott
A decarb takes the carbon out of the cylinder, pistons etc... Search on decarb on this forum and you will find plenty.
The carb clean and rebuild takes the gunk and old solidified gas out of the carb and teeny tiny holes in the carb to let the fuel flow where it's supposed to flow and make the engine run how it's supposed to run...
mobytodd
Thanks. When you guys say rebuild... You do mean put a new kit on them... right
samo_ott
Yep. Take the carb(s) off and apart and clean and replace all the seals, gaskets, etc with a carb kit. In the older models it took longer to re and re the carb then it did to rebuild it.
mobytodd
Steve I am so new to this till... LOL I have the carbs off now and I am awaiting the rebuild kit. I am soaking the carbs themsleves in seafoam to maybe break up any build up they may have internally.... Once the kit comes in then I will reassemble and see what happens.
rockyrude
Before you put everything back together, blow all the pasages out with a compressor. The rattle cans won't work.
Evinrude Boater
I could be wrong but I'm not sure Sea-Foam will do the job. When used in an engine it burns off carbon after soaking. Carburetor cleaner works miracles and you can spray it into the orifices. It's formulated to break down varnish from old gas. I agree with the recommendation of using compressed air. Mine didn't work properly until I blew it out and something caming flying out of the carburetor and hit me in the face. Wear your safety glasses!!!
georgiaboy
is there a cleaner you can put it the gas that will clean out any resident gunk even though the engine may not be to the point of having to run on choke- like a spring cleaning so to speak??
