Re: Tapered roller bearing
Quite possible you have an 'R' top box (serial number will identify that and I'm at the wrong computer) and you could have any of the following lower box... MC-1, R, MR, Alpha 1. All will bolt straight up. The fact that you have the driveshaft bearing going on from the pinion end means you have either a MC-1 or an R lower unit. Do you have an 'O' ring groove at the top of the driveshaft? If yes, then you have an MC-1 lower box. Do you have plastic inserts in the water intakes? If no, then your lower box is pre-1974. If you don't have an 'O' ring groove, then it could still be an MC-1 because if it's had a new driveshaft at some time in the past it will have had a 'O' ring-free one put in.
Chris.....................
Edit: Now at the right computer and the serial number you gave is for a 1983, 'R' top box.
