can some one help me please
nsowers
i need to know what year of mercury 150 i have all i have is this serial number O8129695 or it may be 08129695 sorry new to this boat stuff but i need to find out the year i need to fix the water pump and power tilt and trim motor i test the tilt and trim motor i got power from the cylonlids to the motor but it does not move bad motor? or am i missing something
thank you for your time
nathan
AMD Rules
Re: can some one help me please
Serial Number: 0B129695
Model Number: 1150766
1987 150HP V6
achris
More fish than mountain goat
Hi,
Welcome to iBoats the serial number you have posted is not right the second character you have as 8, should be a letter either A B C D or G with Mercs you don't need the year just the serial number having trouble reading your post any chance of adding a full stop or two to the ends of the sentences? i think you're saying that the trim and tilt motor isn't working when you press the up or down button, can you hear anything a click or a whirring?
Chris...............
D
DJ
Guest
If you have power to the motor and it doen't work then yes, I would suspect the motor.
nsowers
it might be a B but the left side of the letter/number looks rounded so either a B or a 8 . does anyone know how to remove the power tilt and trim motor ? or is it best to let a pro do it? i work on cars for a living but the merc 150 looks intimadating for some reason
Don S
While you may have power from the solenoides, do you have a good ground from the pump motor?
It may be easiest to disconnect the wires for the pump and test them directly to a battery. Black on Ground, Blue or Green on Positive. If it doesn't run when wired direct, the motor is bad, or the pump is locked up.
