I had a thread asking about water in the hull and y'all helped me out. My son and I are doing this whole thing as a father-son project He's 13) and we're gettin' after it.
We took the deck and foam out in about 3 hours. Still have to grind down the edge, though. Someone asked me how water was getting in. This was apparently done before and some genius made holes to drain the space w/ holes through the little drain sump wall. But they put them about 1" off the hull, so all they did was let water in, not out.
1) The lengthwise ribs (stringers?) are fiberglass. Are they fiberglass over wood and have to be replaced if wood is gone?
2) What foams are available? There is the XEPS (blue or pink insulation board) and the 2-part, pour-in expanding urethane foam. What else?
3) is the urethane foam these days completely resistand to saturation? The XEPS is pretty close, but will dissolve with a small amount of gasoline.
4) Will the auto insustry polyester resins work, or is there a special marine grade.
5) Is marine-grade, teak plywood the only deck to use, ore is there something else? Far as I can tell, it's $100+ per sheet. Not in planned budget.
6) There were no cross ribs, side-to-side on top of the stringers. Is that normal? Should I put some on?
I know this is lengthy, but these are the ones I couldn't find on other threads.
Thanks a lot.
JDC
Thanks a lot.
JDC
