fishinfreak27
- Joined
- Jan 14, 2008
- 1
I think I have a similar situation as the prev. post with a 200 Opti... This has been an ongoing problem since last August. We have had it into 3 diff. shops now and haven't gotten a solution. So, any and all info is appreciated. The motor will run fine, then all of the sudden the check engine light comes on, and the intermitent beep beep comes on, also, the motor slows to 3,000 rpm. When you stop and put it back into neutral that usually always stops it, then it may go again for another 5 min., or less. Many times when it does this, once you try to go again it won't even let you get back on plane before it goes off on you again, then again. It seems we can go a couple trips with no problems, then it goes off, and it happens several times in one trip. Also, the motor idles higher than it should, 900 rpm, I believe, about half the time. Several people think it may be one of the tps sensors. I have had it at the marina, and they couldn't find anything when they plugged it in to the computer. Just one over-rev. I do have a hot foot, don't know if that has anything to do with it. Replaced the fuel pump, that didn't help. Any ideas guys? Thanks
