ddennis
- Joined
- Aug 15, 2006
- 351
Ok.. I checked my warning horn and all works fine. EXCEPT it does not beep when I first turn on the key. It also does not beep when the starting battery is disconnected and reconnected. I have a tan wire under the console that is taped of and disconnected from the ignition switch...and one under the cowl of the engine that is not connected. I see no where to connect it. I assume this is for power to the warning module? The horn will sound when I ground the wire from the temp sender, I also know the horn will sound when running and my oil tank gets low on the engine. I ran it low on purpose to change to synthetic oil ( I know, wasnt necesary to run low, Personal preferance).
Any thoughts?
Any thoughts?
