I am experiencing a nerve racking problem on my 1998 90HP Johnson outboard. The issue only happens when I am on the lake, I cant reproduce it at home.
After running the boat out to my fishing spot, cut the motor off for 5-10 minutes, the boat absolutely will not start unless I throttle it up a good bit. The first time it happened I had someone with me, and even though the bulb was tight, I pumped the bulb while the other guy tried to start and I believe at that time it would sputter a little but but not start. I then decided to throttle it up and try to start and then it started right up. It experienced the same behavior the rest of the day and did it the last time I took it out. As long as throttle it up, it will always start.
It seems like when I first bought the boat the bulb would stay tight for weeks, but now it leaks down after a few hours, I assume that could be one of my problems.
Are my assumptions correct that it could be the fuel pump, air in the fuel line, or bad bulb?
Why cant I reproduce the problem at home?
Could it be heat related? Could something ignition related be happening after it gets good and warmed up? My intuition tells me no, since it seems to be fuel related since it starts after I throttle it up.
How can I troubleshoot?
