Re: Alarm - Oil?
there are no oil alarms other than the alarm for low engine tank level. unlike merc or suzuki there are no rotational or flow alarms.
oil brand is irrelevant for any yamaha 2 stroke oil alarm.
the digital tach, or on older models shows a temp icon if its overheat,most likly it is, if it oil your tach display will flash the red bar or lamp.
while running a 50/1 premix certainly wont hurt my guess is its a leaking poppit valve and the stbd cylinder overheated on the muffs.
yamaha uses no oil sensors that can clog, simply a float switchthat contains 3 switches,SW1 turns the transfer pump off,SW2 turns the transfer pump on, SW3 sounds the alarm. all 3 use a common ground.
SWB is located in the remote tank and is normally closed, one of the few signals yamaha uses that when its open(no ground path) a lamp lights.
but no alarm with SWB.
ps scuse all the typos, this keyboard here in caracas sux, but the rum is very good
but like I say, my money is gonna be on a bad poppit or pressure relief valve grommet allowing low water pressure to let #1 cyl go dry.
