Online source for stripe remover disc?
erikgreen
Hey all -
I found a solution in an old thread here for removing old pinstripes that involved use of a rubber disc that fits in a drill to abrade them away.
Here's the thread link: http://forums.iboats.com/showthread.php?t=193525&highlight=stripe+removal
The old thread said the disc can be found at "any auto parts store". Except the ones around me, apparently.
Anyone have an online source for one of these? Heat gun and a plastic scraper are gonna take a looooong time.
Thanks,
Erik
defcon5
Re: Online source for stripe remover disc?
I got a coulpe when I used to work at a place called Fastenal. There in just about every town. They are made by 3m. Just like what you said mount to a drill.
Roman
gcboat
The stripe remover is mfg. by 3M under their Scotch Brite name. Their part # is 07517. Also called a LASR ( large area stripe remover). That makes sense.
Just can't tell you where to find them in your area but possibly that number will help you in your search. Sorry I couldn't be more specific. :(
D
DJ
Guest
Look in your Yellow Pages for auto paint supplies. They'll have it.
degree
Hey all -
Thanks,
Erik
It's not available at an auto parts store, but a body shop/paint supply store. It isn't too expensive and will last for some time. It is also call an 'eraser wheel'. The article in which I learned of this also states that, to remove the leftover adhesive, you should use lacquer thinner as acetone stains the gelcoat. I used this set-up to remove the name from my boat and it worked just fine! Get the lacquer thinner when you pick up the eraser wheel and be sure to ask them for a body filler squeegee--it helps pick up the edges of the vinyl.
erikgreen
I found one at the local red rooster... $35. Works like magic, though.
It's abrading away fast... looks like I'm going to need 2 to do the whole boat.
Erik
