Help. I have a 1998 50hp honda 4 stroke that was running fine then started missing. I found water in the middle plug. It has been running in salt water since I have had it for a couple of years. A local shop looked at it, took the intake mainfold off and said I more than likely
have a cracked head. Now the question, is Honda prone to cracked heads and should I repair or replace. I liked the Honda engine but have heard that the alloy they use in the head is prone to cracking in salt water conditions. Is this true, and should I be wary of replacing it with another Honda? Any guidance is appreciated. Dave
