i get 18 knots at full throttle well the boat i heard is 4550 pounds there was 4 person on board and the boat plain off at about 15 knots, what can i do to get more speed ? (mercrusier 5.7 litre 350 hp , prop 15x17).
When was the engine last tuned? May be running on half its cylinders? Fuel tank contaminated with water or fuel that has gone bad. Carb may be due for rebuild. Dirty hull and as was mentioned, lugging around a boat load of water soaked foam doesn't help. You have gauges! What do they indiate? Water temp, oil pressure, volts, and tach (at wide open throttle).
I think Capt Jason's signature line works here.
"just because you found it that way... doesn't mean it's supposed to be that way. "
Ayuh,......
Marine Distributers Don't use Vacuum....... So there are No vacuum lines......
The Fuel Pump should provide 4/ 6psi to the Carb.......
Internal centrifugal weights.....so what is used to advance the distributer ?
Internal centrifugal weights.....![]()
Bond all of those was flooded by the greaT HURRICANE IVAN so i was left with nothing apart from the iv amplifier.Ayuh,......
Actually,... Your 1992 should have the T-Bolt IV system which is electronically controled.......
