Checkmate Perry
Thread starter- Joined
- Oct 8, 2007
- 9
I recently got a 83 150 v6 merc with an overheating issue. I replaced the water pump, missing thermostats & new poppet valve. Temp guage reads 170 180 on the hose.Water out the pee hole is hot,water out the prop is only warm..Water psi is 4-5 at idle,9 10 at fast idle..I also removed heads to check for salt build up. All is clear! How accurate is that temp sender that doesnt touch water? Temp gun reads about same as temp guage?
