1995 Bayliner Capri, 3.0 Alpha-1 Gen11.. Just dropped the outdrive back off to look for bad/missing seals due to the prior post where I tried to fill the drive through the reservoir and ended up with the oil on the floor. Well after separating the lower unit I found were the oil travels from the upper to lower drive and the small o-ring that goes there is missing.. Hope this was my leak. My question concerns the drive shaft that runs through the impeller,, where it goes into the upper drive it appears to have an O-ring but I can't tell, I looked in the manual and can't seem to find it. I would like to make sure it actually has one there before I start digging around in there.. Ideas??
