scottfromoz
Thread starter- Joined
- Jan 1, 2006
- 90
Hi fellas - 500 hour motor. Always been a great bit of kit. Just had a full service 3 months ago and have not run it since (warm climate - no ice etc) - new thermostats, impeller kit, seals, plugs etc. I took it out for the first time yesterday and it had a strong tell tale at idle and up to about 3000 rpm and then I thought it was a little different at above those revs and not quite normal...heat alarm went off and motor cut 2 cylinders and after idling for only 3 seconds or so the heat alarm went off and i had full power back. I went back on the plane again and its fine at 3500 rpm, but creep up to 4000 or over and within a minute of so the heat alarm goes off again. Keep it under 4000 and she goes all day (which I then did). The **** tale is still strong at above 3000 but seems to stutter a tiny bit..hard to describe.
I assume that my new impeller is damaged.....any ideas?
Cheers
Cheers
