Faster Prop Johnson 15
JF123
Hi,
I am running a Johnson 15 (1978) on a tiny 8ft Hydroplane (Minimost). The boat is way overpowered. This boat could easily do 40 MPH but I have the regular prop 9.5 x 10. I would need a prop with a least 15 pitch. I can't find anything that would fit this motor. There are 10 x 15 props for OMC and Merc 25 HP avalable but they don't fit the 13 tooth spline on my motor. Can the hub be changed on most props ? Or is there any other options I haven't considered ?
Thanks in advance!
JF
ezeke
Re: Faster Prop Johnson 15
OEM prop # 175323 was 12.5 pitch if you can find one. ADVANTAGE PROPELLER DISCOUNT CENTER still lists them. 1-888-757-7767. I don't see why their prop shop could not turn the blades to take it up to 15 pitch.
jay_merrill
If you can find the 12.5" prop, you may be able to have it pitched up to 13.5" - 14"
Frank Acampora
Go over to hydroracer.net and join. go to the general hydroplane forum. Those guys should be able to set you up with anything you want---including very expensive custom props.
