Shifflett115
Thread starter- Joined
- Jun 11, 2007
- 191
whats up guys, im currently redoing the transom on my 1985 bayliner 19ft cuddy,its an outboard boat.it only has one layer of 3/4in ply on the transom ,im going to use epoxy resin to attach the new wood to the outside skin and to the wood at the bottom that is still good, bsaically im just replacing the main section of the transom,not the bottom ,then im going to use two layers of 24oz woven roving and fiberglass resin to make a new inner glass wall,will i have a problem with the fiberglass resin bonding to the epoxy resin or will it all just bond together, im also going to add two gussits out of 2by 10's from the transom to the stringers at a 45 degree angle,do you guys think everything will work out,your advise is greatly appriciated,thanks guys
