troubleshooting electrical components
gatorman21218
I was wondering how to test the various parts of the electrical system on my 5 hp 1990 2 stroke. specifically the capacitor charging coil, the trigger coi, and the CDI unit. thanks
Laddies
Banned
Re: troubleshooting electrical components
Stator test + to red, - to black, range set at R x 100, 93 to 142 ohms
Trigger test + to black, - to red/white, range set at R x 100, 80 t0 115 ohms
Coil test + to red, - to black, range set at R x 1, 3000 t0 4400 ohm
There is no switch box test
gatorman21218
maybe i am missing something but all these parts seem to be called 3 different things. I have a white coil that has a red/black and white wire that came from under the flywheel. I have a black coil that leads to the spark plug and a black box with 6 wires( red/white, white, black/yellow, black/red, black and brown. could you clarify what these are called?
Don S
You really need a service manual. It shows what each part it, how they are wired together, wire colors, and all the tests (not just ohms test) of all the units.
The CDI unit cannot be checked with an ohm meter.
BTW, what is your actual problem with the motor?????
gatorman21218
i have a seloc manual but it is confusing. If you look at my other post you can read about my problem but basically it was missing and then not idleing right.
