Im looking for carb kits parn #'s
drewmitch44
I have a 1986 yamaha 115 ETLJ and im looking for carb kits for this motor without any luck. I found a list of parts of everything but i was hoping to find a kit for this motor. This is a V-4 2 stroke motor with 2 carbs. There was a whyle where i was pre-mixing the gas and i want to rebuild the carbs. This is a precision blend motor and when i bought the motor it had sat for a whyle (2-3 years) so i was not sure that the oil injection was working so i premixed for most of the summer of '07. So it runs ok now but after i confirmed the oil injection was working and started running straight gas i added seafoam and noticed that it started a lot easier. So i then looked in the carbs as good as i could and i saw a bunch of Junk that i want to get out of there!! I can start the motor easily now even when cold but this is something i need to do. Any help with a part number would be greatly appreciated!!!
drewmitch44
Re: Im looking for carb kits parn #'s
Ohh i usually get my parts from boats.net and i dont see a kit on their site. Maybee ill call them tomorrow. They are open for a couple hours tomorrow. Thanks for any help you guys can give me!!
Crapduster
Try this. http://parts.yamaha-motor.com
Select you year/make at the top, after the page refreshes, select "repair kit" on the right hand side, should be fourth from bottom. A list of parts will come up... In that list are repair kits. Looks like you can buy them online. Hope this helps. here's a screenshot of what I saw.
boatguy823
here's the yamaha part number for the kits called for with that engine....6e5-woo93-02-00 not sure if its got parts for all carbs or if you have to buy kit for each carb.
drewmitch44
So whats the diffrence between these 2??
6E5-W0093-02-00 is the "CARB REPAIR SET" which is $33.93@ boats.net
and this one:
6E5-W0093-06-00 Is the "CARB REPAIR KIT" which is $24.17 @boats.net
Im not sure what the difference is. Wonder if the set is both the carbs just not sure. Both of these part numbers i got right off of yamaha's site.
drewmitch44
If you go to that place that popster posted there is a double bowl kit that i think is the one i need but im not sure. That place has their own part numbers and then there is a list under that with like 3 yamaha part numbers and if i plug those into boats.net one of them is like 100 bucks! so that place that popster gave a link too im not sure about that one now eather. I just wish i knew what i need to do these carbs!!
Crapduster
I know how you feel. I wondered the same thing when I saw "kit" and "set".
Yamaha.com should have an email address or phone number for sales contacts since they sell stuff online. Take advantage of this and get Yamaha's sales guys to explain what the difference in a kit and a set is.
Pretty sure they can help you get the right parts.
CrappieDuster
Popster
I bought set for the double bowl carbs. Will check tomorrow if I can to see if it was for one or two carbs. I think one.
I was able to clean carbs using existing gaskets with no problems.
drewmitch44
Anyone know? Rodbolt are you out there do you know what I need? Id really like to rebuild them this winter so they are good to go for the spring. Thanks for all the replies so far but im still not sure what I need.
