Fuel problem.
tigerhack
fuel pressure would drop to 0 sometimes also causing the engine to shut off ,i also remove my little glass filter and the same thing ,the filter is quite clean , and the pump is pumping ,what is the problem ? could it be my water seperator ? are blockage in my tank ?
Re: Fuel problem.
Ayuh,.......
1 More thing your boat Shouldn't have,....... But does.......
180shabah
Re: Fuel problem.
Ayuh,.......
Is it just me, or are others loosing faith in the possibility of a good outcome, with no casualties????
Re: Fuel problem.
It's not just you......
Well,...........
Have a Look at what's being worked on,.....
Then you tell Me if I might possibly be Off Base here,.....
But,......
This sure looks like a Death Trap to Me.........
Bt Doctur
Re: Fuel problem.
Kinda looks like an automotive carb with all those hoses and I`d replace that fuel hose with the correct steel line before it springs a leak and you`r nominated for the "Darwin Award" .
Don S
Re: Fuel problem.
Yea, Bt, we went over all that with him when he posted all his pictures. He just didn't listen. But it still won't run.
The carb IS automotive, you can tell by the bowl vent under the little metal box just under the front of the flame arrestor.
What do you want to bet those aren't even stainless steel screws plugging the vacuum lines :p
Haut Medoc
Re: Fuel problem.
Is that not an automotive distributer as well?.... :eek:​
JustJason
Re: Fuel problem.
yep!
I've found something else that I like more than the custom fuel line.....
I absolutely LOOOOOVE :) :) :) :) the custom carb return spring mount
Don S
Re: Fuel problem.
yep!
Believe it or not, I have seen the same setup on many boats.
I've always called it the "WHY Spring"
As in WHY do you have a spring there, when all you have to do is adjust the cable so it will idle?
watermellonI
Re: Fuel problem.
yep, I think yall are right,(as always) except for the fuel line, I did find a post where you can use marine grade hose instead of steel, I had to replace mine and the steel line in nla,
Flukinicehole
Re: Fuel problem.
The spring should be there as a back up(cable breaks or screw falls out) the mount on the other hand ???
JustJason
Re: Fuel problem.
i have a carb return spring on my boat to. But it has an actual mounting location... not slapped to a hose clamp.
