prop change out
jusfishn8124
i have a 1957 johnson 5.5 cd-14 SeaHorse and need advice on how to change prop. Also would like to know what I need to do to keep motor runging at low idle speed.
Thank You
Jusfishin8124
steelespike
Re: prop change out
Remove cotter pin,remove propeller cap, remove drive pin, remove propeller.
reverse procedure.
Low speed mix adjust.. gently seat then turn out 3/4 turn with motor warm
in gear adjust to best idle.High speed same procedure final adjustment at speed.
