mercruiser 3.0 l
isla
Hello, the carburettor there 'a device that certainly need to start cold,(choke) as commanded? Where can I get whiring diagram of the engine
Thanks to all
Haut Medoc
Re: mercruiser 3.0 l
What year?.....:confused:
On newer stuff, I believe it is a purple wire, but you will need to post the year.....
isla
sorry! 1998
in the elettric choke is a wire purple!!
Ok,.....
You've got a 1998,.. With an Electric Choke which uses the Purple Wire,....
The Purple Wire Should be Hot with 12V, whenever the Key is in the On position.....
What's your Question,..??....
Don S
Can you get the Mercruiser Serial Number? You may have a 97 engine and I have a link for it's service manual, but not one for a 98. Either way, the wiring diagram is the same. Here it is.
isla
Ok,.....
when the motor is hot,and the key is in on postion,the choke is not 12 v ?
There 'a temperature sensor that pilot choke?
I do not see sensors, only water temperature
Don S
Did you test the wire with a volt meter?
isla
the nex time the serial number!!
Don S
You DO NOT have to run the engine to see if the choke operates.
You need to use a voltmeter and check if you have voltage at the purple wire on the choke coil.
Here is how that choke works.
When voltage is put to the choke coil (also know as a choke cover in the service manual), it heats up the spring inside and pushes the choke plate open.
If you have a bad ground or no power to the choke coil, then it will not operate. If you have a bad choke coil, it will not open. You have to use your meter to determine which is defective.
isla
Sending serial number engine
OL 064129 YEAR 1998
Thanks for your availability '
isla
Know the reason for the operation, and 'given from start cold, the engine seems to be starting a 3-cylinder, compression ok, new spark plug, new cables, new distributor cap! 30 40 seconds later appears to be operating normally at 4 cylinders
Why?
tommays
The translation is hard :D
But the choke is stupid, the purple wire just heats a spring that opens the choke plate in about 40 to 60 seconds
The rough running during the the first 40 seconds sounds about right You have to use the tack and run the motor at about 1500 RPM during warmup
It will never run like a modern car with fuel injection ;)
Tommays
Don S
Is this the first time you have owned an engine with a carburator on it? It sounds as though things are working nomal.
The 3.0L engines ALWAYS run very rough when first started while the choke is closed. As the choke opens (electricaly as Tommays mentioned) and the engine warms at the same time, it smooths out and will run fine.
That is just the way a carburated engine works.
Yes, your engine is a 98, sorry, no service manual available online.
isla
The engine and 'my brother, I always had injection engines,
Thanks to everyone, and thanks for your patience you have against me
And 'all clear
no problem for manual!
