QC
Thread starter- Joined
- Mar 22, 2005
- 22,783
For my Monaco project, for budget reasons, I am trying to use as many of the pieces that I received with my purchase. I have two automotive manual steering boxes that would work very well and I am considering a cable system like this:
The little shaft shown pointing to port off of the steering wheel shaft is the boxes output shaft, a "steering lever" will move fore and aft off of that, hence the need for the first two pulleys (blue mini-circles).
Is this a good plan? I have seen references to a steering quadrant when using a system like this and I fail to see the need. I have the steering lever on the steering box now and I cannot get any feedback to the wheel pushing and pulling on the lever with all that I have. I have a matching length tiller arm for the rudder shaft, and the steering box turns 90 degrees which should be 45 degrees in each direction. All makes sense to me other than the relative simplicity makes me wonder why it is not used more . . . Thoughts?
How much load would you expect on the steering cables etc.? The rudder is 12 x 7ish and I want to make sure that I get pulleys and cables of sufficient load capability.
