Who has a u-joint retainer tool?
G1K
Just in case I find out this is expensive, I can EDM one next weekend. If there is anyone who has one, and a flat bed scanner, can you scan the tool for me? Or is there a drawing online somewhere that shows the dimensions?
I'll stop by west marine tomorrow and probably find out the tool is $20 or so, in which case...
Oh, found it online. I can EDM it for less than $60+, and I'll hae fun doing it.
Ryan
Don S
Re: Who has a u-joint retainer tool?
EDM it ????? What the heck does that mean?
If you are talking about the C clip that holds the ujoints in, Personally I use a couple of screwdrivers.
One to keep it from turning, the other to pop it off the bearing cap.
ziggy
think he wants a brg. retainer nut wrench... there bouts 67 dollars here on iboats.... i got the serria one. worked ok for me..... lean a couple hundie on it maybe 10 times......no issues.....
yeah, i found it that way... half in new tools, half in parts.... and i didn't need a dial indicator type in. lbs. torque wrench....
ziggy
rough guesstimate... the sierra tool ya got linked...
outside dia. of tool. 5 3/4"
inside dia. of tool., 3 9/16"
small hole dia. 1 1/16"
8 holes... equadistant
thickness 1/4' plate
thickness at drive end. 1/4" plate X 2... welded four sides...
drive end 12'' from center of tool center...
G1K
Ziggy, thank you, exactly what I need. I'll post up the results of the home brew next weekend.
Ryan
