Bigprairie1
Thread starter- Joined
- Jun 13, 2007
- 2,568
Ok, as I posted in the fall I am trying to put together a 91' 90hp force from a 'broken lower unit' motor I bought last summer. Supposedly the power head is good. I bought a good used lower unit for it and now I have to get these two together. I am hoping to have this motor as a spare or perhaps put it on a second boat for me and a buddy of mine to use.
What I would like to know is should I just do the impeller...or should the entire water pump be replaced? (or other stuff too?) How do you tell how far to go on this? The motors serial number is 908A91H.
Note: the lower unit I bought looks very good and it appears to have a very nice intact looking water pump unit it on it...although I have not checked its impeller....yet.
Next question: what does the little rubber flexible tube connect to that is connected down into the front of the lower unit?
Next question: can the motor be compression tested (successfully) with the lower unit removed?...any danger of anything getting out in the process or over spinning or other things to watch for?
Next question: prior to doing the impeller...or the water pump...or both? is there any major step to do or something to check or align before bolting the unit up onto the motor?
Next question: do these impellers and/or water pumps vary a lot in these years? (referring to the serial number listed above)...or are they all pretty common?
Ok guys...many thanks in advance...hopefully you can wade into this with some much needed advice.
BP
BP
