Re: One Bank, two Batteries
An ACR is short for an automatic charging relay. Simply put it is a relay that automatically closes a connection to a second battery when a charging current is available. Once the charger is disconnected the connection is broken preventing the second or backup battery from draining the primary or starting battery.
Blue Sea Systems makes a kit that includes a battery switch that allows you to combine the batteries in case of an emergency. It's called the Add-A-Battery system and if you search the forums you should find multiple posts talking about this system.
http://bluesea.com/category/1/productline/docs/329' <--- Add-A-Battery system
However; this setup might not be exactly what you need...
An example wiring diagram would be:
This setup would automatically charge the starting battery (battery #1) and the trolling motor battery (battery #2) while underway provided your engine's charging system has the output to charge two batteries. It would also allow you to connect your charger to battery #2 and battery #1 would also receive charge.
It looks like you just want to make sure your starting battery is topped off after the trolling motor is charged. I really like the ACR setups but they may or may not be best for your situation.
Some considerations:
1) Your engine is supposed to keep the starting battery charged. Going to the trouble and expense of the above setup just to make sure the cranking battery is charged is probably not the best route.
2) If your engine is an outboard it may not have the output needed to keep two batteries charged (as it will be trying to do with the above setup) Check a shop manual on your make/model engine for its charging system limitations.
3) A simpler solution may be to install a 1-2-OFF-BOTH switch that would allow you to connect the batteries in parallel for charging (or to charge/crank with either battery). When you get ready to go out just switch to battery #1 and crank up and go. However; then you have to remember to switch off of the BOTH setting otherwise the trolling motor battery #2 can drain your cranking battery...
4) Another simple solution would be just a simple ON-OFF marine disconnect switch connected between the positives of both batteries. When you connect your charger you switch the switch to the ON position. When you remove the charger switch it back to OFF.. This setup isn't as versatile as the 1-2-OFF-BOTH style switch but would be simpler to set up.
5) Lastly you could look at a large high current relay that could be wired to a switch on your dash. Switching the switch to on would connect the batteries for charging and may be easier to remember.
http://bluesea.com/category/1/productline/8' <-- High current remote relay.
