oops!
Thread starter- Joined
- Oct 18, 2007
- 12,932
Re: hull extension in progress with picks
it was now pushing 11 00 pm ish....and defenitly beer-o-clock....
as i was sitting there sweating with a cool one in my hand...i knew i would not be able to glass the strings tonight...i didnt want to stop on the boat so i decided to make the outer set of stringers and the motor mount structure.
i took the measurements...cut the stringers....with the grinder i shaped them to the hull......
then gave them three coats of slo kick resin.
the resin was on every edge that would be bedded.....
i actually built those pretty quick but it was still an hour or two......so.....beer-o-clock again.
as i was sitting there....i was kinda dissapointed because i didnt get the strings glassed in...i started thinking....(it was 2 am)... "i should bed these puppies tonight"
so i grabbed the bubbles, cabosil, resin. and my trusty mixer and started making peanut butter........
after bedding the new strings and motor mount system
it was 3:40 am....i started thinking again....the peanut butter will be kinda weak tommorow when i cut them down to size.....so i decided to tab them in....
next job....to do what i wanted to do yesterday !
cheers oops
cheers oops
