Benny1963
Thread starter- Joined
- Sep 17, 2006
- 1,476
1976 115 whent to run comp check. starter seemed to run alittle slow
battery was not hot or starter was draging . i got 60 psi per cyl across the board . does the battery have to spin a full capacity to run comp check these numbers were low but not sure motor turned fast enough
motor has sat should i spray some wd or deep creep and try again with good battery or can i get good reading with motor turning over slow
thanks bennyb
thanks bennyb
