1987 125 Force shifting issue
pberry
I just bought a Bayliner Capri with a Force 125. The previous owner stated that I should replace the impeller before running the motor. I pulled the unit using the forum advice I found here, and discovered that the impeller was fine, but the seal had pushed out of the top of the housing. The housing itself is pretty corroded so I will be replacing the entire pump assy. anyway. Poking around and looking at things with the l/u off, I discovered that I cannot move the shift rod up or down. While it was all together, I did move the shift lever both forward and back, but it would only go about halfway backward. Pardon me for being a complete newbie at boats, but I do have extensive mechanical background with cars and motorcycles, just no experience with outboards. Any input would be appreciated.
Scaaty
Re: 1987 125 Force shifting issue
You need to turn the prop while shifting (or motor running)..or the clutch gear dogs just hit each other, and not mesh.
It will be difficult by hand with the leg off, and not all the needed leverage provided with the shifter and related.
And DO NOT take out that side gearcase Phillips head screw..NEVER!
Frank Acampora
If the pump housing was that badly corroded, you also need to check the walls of the lower plate. That's the plate held on by an additional three screws--one in the front and two in the back. There is a center wall in this plate below the stainless plate and gasket. If this wall is corroded enough that it does not seal against the gasket, it will short circuit water from the outlet side to the inlet side of the pump. This can reduce efficiency enough that the engine may overheat even with a new impeller.
This torpedo shaped plate also carries the drive shaft seal and the shift rod seal.
Sometimes with age the shift rod seal will swell and tighten on the rod OR with improper installation, it will be too tight resulting in the engine being able to shift because of the leverage in the system YET, you can not move the shift rod by hand. If this is the case rather than the dogs hitting each other, then remove the plate , remove the old seal and reinstall a new one--it only costs 8 bucks. It is installed steel side up, rubber side down. You press (hammer) it in using a suitable sized socket and a piece of pipe (Because you install it with the plate on the lower unit and the shift rod in place). It should be snug enough to seal out water yet the rod should slide smoothly through it. So start a little loose and continue to tap it in until you get to the correct compression. As I said, you should feel a little drag when moving it by hand but it should not be excessive and it should be smooth You should be able to move the rod by pinching it between two fingers with moderate pressure--anything more than that is too tight. If you got it too loose and it leaks a little water, you can always tap it in a little tighter.
The drive shaft seal is either 17 or 27 bucks and if you need to replace the plate, you must use a new seal as you can not remove the old one without damaging it. Even if the old plate is OK, It might be a wise move to replace the seal anyway.
