Re: Minimum Cloth At Base of Stringer to Glass In Stringer
hey m spring.....
thoes stringers are the frame of your boat.....
they need to be nailed down.....uh...... not literally.....
if your stringer is 6 ins high and one inch thick and the first layer you want a 3 ins each side stringer hull contact point...(overlap)....
then you cut your cloth at. 6+6+1+3+3=19 inches.....
your next layer...you want a 2 inches overlaping the other cloth...so it must be wider... thats 6+6+1+5+5=23 inches wide
your third and final...you want another 2 inch over lap...
6+6+1+7+7= 27 ins
each layer overlaps the preivious.... and each layer has more hull contact than the last layer......that way all three layers have minimum 2 inches of hull contact and all reinforce each other
now ....having said all that ...remember that the stringers are probably not 6 ins high all the way thru the bote...they may be closer to four ins near the back....(transom)....dont worry about it.....either cut the cloth different or trim it in place.....or just leave it....giving you a wide hull contact point...
kinda confusing but
i hope that gives you a clear picture
cheers
oops
