spary carburetor cleaner in to carb while it running,good or bad?
jjdluz
i woundering it will be ok or bad spary carburetor cleaner in to carburetor while it running?and how good it does most of time clean carburetor?thanks.
drewmitch44
Re: spary carburetor cleaner in to carb while it running,good or bad?
What motor are you talking about? As i just said in a different post there is a lot of us here that can help you but you got to help us help you by giving as much info on what motor you got as you can. If you got a model number and description of the motor that would be about 90 percent of the info that we need to help ya out.
jjdluz
it is 1992 yamaha 200 outboard,thanks for some good advices.
rodbolt
I just gotta ask.
why would you wish to spray a solvent into a running engine?
if the carbs are dirty inside no amount of external cleaning will help. if they are dirty the only method is to remove,dissasemble and clean.
It will clean the carb bore real well. Unfortunately that's not where the problem lies. The cleaner needs to get to the internals of the carb. There are only two ways in: 1) mixed with the fuel or 2) remove and disassemble the carbs for cleaning. #2 is the best.
jjdluz
hi,thanks,what about use one gallon gas mix with fuel injector and carburetor clean hook to gas supply and run it little bit ,i just want to try easy way see it will work or not,if not i will still take carb apart,thanks.
rodbolt
usually by the time the gunk is cleaned you have detonated a piston from lean running, but its your motor
Capt Ken
I can hear the knocking and pinging from here.
jjdluz
sound like not to many people will do that,lol,would it help mix more oil with gas and carb cleaner will cut down chance burn the piston?
bgbass.1
Instead of taking a chance of ruining the motor just take the carb. apart and clean it
