update shifting problems
rowdyrebel
Update: thanks to all you my boat shifts like a brandnew one:) thank you so much.
How ever I have another ? for all of you.
When I exselerate some times I here a cluck come from the outdrive, any ideas?
And again thanks for the help with the shifting problem.
JustJason
Re: rowdyrebel
Re: rowdyrebel
a cluck??
personally.... i'd check for chickens.
woosterken
Re: rowdyrebel
Re: rowdyrebel
is it a cluck or a clunk?
if it is a clunk it is probably just the cluch ingaging
my mercruiser dose that
woosterken
Haut Medoc
Re: rowdyrebel
Re: rowdyrebel
Are you putting it in gear, then accelerating?.....:confused:
Don S
Re: rowdyrebel
Re: rowdyrebel
What kind of drive are we even talking about?
rowdyrebel
Re: rowdyrebel
Re: rowdyrebel
Its a clunk,no chickens in there. LOL
Its a 89 OMC drive (W) a 2.3 ford 4 cyl.
I fixed the the shifting problem with everbodys help "THANK YOU" but there is still a clunk comming from the outdrive some times
rowdyrebel
Re: rowdyrebel
Re: rowdyrebel
Coors
Re: rowdyrebel
Re: rowdyrebel
Clunk when putting in gear is normal-anything else means a teardown.
Hashi
Re: rowdyrebel
Re: rowdyrebel
My Mercruiser also clunks when engaging but before it engages, the drive gears chatter. Is this normal?
JustJason
Re: rowdyrebel
Re: rowdyrebel
its normal if your shifting slow.....
but it's bad to shift slow.
shift faster.
rowdyrebel
Re: rowdyrebel
Re: rowdyrebel
There was a lot of corrosion around lower end of the transom cable.
Cleaned,adjusted and lubed everything it works with the greatest of ease:D
But now the ignition went south:mad:
Like that other feller said i/o i/o so off to work i go.
JustJason
Re: rowdyrebel
Re: rowdyrebel
damm.... i was really hoping for chickens. ;)
HT32BSX115
Re: update shifting problems
Do not mess with that lower shift cable. It must be replaced when it gets corroded.
If it gets bad enough or gets frayed internally and starts stretching it will pop you into or out of gear when you least want it.... and tear up the "dogs" in the process.
