Evinrude Electra Shift
fishindog
I wanting to know if they make a cross over plug from the Round 10 pin to the flat 10 pin OR can someone tell me how to wire controller to motor .It Is evinrude controller and motor 40hp
F_R
Re: Evinrude Electra Shift
Be careful, the 1960's 40 hp takes a different shift switch than most newer/bigger motors. The switches look alike and you can only tell by doing a continuity test. If you use the wrong switch it will either break a clutch spring or twist off the drive shaft as soon as you put the control in reverse.
fishindog
Evinrude wiring
Evinrude wiring
Need to know how to wire electra shift have round 10 pin plug on controler .10 pin flat plug on motor do they make a cross over plug or how can I wire It?
fishindog
Looking for evinrude plug
The plug is for a 40hp evinrude electra shift its a black 10 pin flat plug male to a 10 pin round male dose anyone have one or know were I can find one
Re: Looking for evinrude plug
Welcome to iboats. you know this is the 3rd time in 24 hours you have ask this. what year motor, what are you trying to do? connect new controls to an old motor? what color is the round plug you have? is it male of female. what is electra shift. model # of motor would tell us a lot. be patient when you post to get answers. multiple post, people start to ignore you.
your threads have been merged together.
itstippy
Read this:
http://forums.iboats.com/showthread.php?t=108291
As F_R says, test the continuity of your lower unit so you know what's what BEFORE you fire it up and start throwing switches. You do NOT want to ruin that old electric shift lower unit. If you have the old-style 40HP Big Twin that has a recoil pull start in addition to electric start, you can test your lower unit's style by using a car battery and a set of jumper cables. Stick nails into the wire plug ports to give you something to clip 12V power to. Try the different color combinations described in the string above to see what you're dealing with. You hook up power to a blue or green, and tug the pull start to see which way the prop turns or if the unit's in neutral. Make sure your controller feeds the + and - to the proper colored wires. Once you know what you've got you can cut the conectors off and wire it up direct if you want, using heat-shrink at the connections. But get it right!
