Exhaust Manifold replacement
rad1026
I have a 1989 Chaparral with a merc V-8 260 HP. I purchased the boat 2 years ago and I have done all the maintenance I can do so far including new bellows and impeller. I have not however inspected or replaced the exhaust manifolds. In the next few weeks I will be removing the manifolds and I suspect will be replacing them since I doubt it has ever been done. So my question, I have seen several types of manifolds from direct cast iron replacements to aluminum and some "hi-flow, less restrictive designs". Can you experienced people give me some pros and cons of the different types of manifolds.
Also, when I get these off, what kind of criteria should I be using to determine if they really need to be replaced? What should I be looking for?
Thanks for the help.
tommays
Re: Exhaust Manifold replacement
ASSUMING :D the boat has spent its life in freshwater :confused: they last a really long time
47b7d700b3127ccebc78171ad8b500000036100AaOWLZq3ct2IA
If you drain them and remove the ellbows you can inspect the condition of the gasket area and get a good idea of there condition
Tommays
rad1026
yes freshwater use only. A really long time? 18 years?
tommays
Well that is a saltwater manifold at 11 years that is trailered and flushed
I have not seen freshwater manifolds rusting out BUT see who else kicks in and idea
Tommays
Mkos1980
Rad, I just purchased a 90 Chaparral 350 V8 last year with the origional manifolds and risers. Freshwater bolt and all, but they were rusting from the outside in from the bottom. When I took them off the insides still looked good. I replaced them with some hi-po Aluminum ones.
rad1026
MK, we have the same boat, mine is the 2100SX. So really there is a chance they may not necessarily need to be replaced? I just need to get them off and make a decision at that time. Just curious MK, why did you go with the aluminum? Where they GLM? I can't see a weight savings of like 80lbs. making much difference of a boat of that size.
Mkos1980
my father went with the GLM Aluminums and I went with the Aluminum Revolutions. I went a little on the hi-po side since I was doing some engine work and added a small cam. After some dyno test both the Revs and GLM's put out the same HP. It was about 8-10 more then the stock mercury ones. So 80lbs and 10 hp. Not bad. Plus I'm never going to see saltwater. i have ye to hear anything bad about them eather. maybe one case or something, but I hear that with other brands too. The GLM's were 504 shipped to my dads door from ebasic.
Ayuh,....
I've got some kicking around here with over 40 Years on them,+ they're still in nearly New condition......
rad1026
Wow, should I really worry about it then? I mean when I drain them I don't get a lot of rust or anything. I guess for the price of some gaskets it would be good to know what kind of shape they are in.
Ayuh,.......
For an Hours time,+ a couple $5.00 gaskets,.....
I'd pull the Risers,+ See if your Gasket Surfaces are in Great Condition like the picture Tom posted.....
While you're there,.... Peek down the Y-pipe,+ see what your Flappers are looking like.......
rad1026
ok so I pull the risers and if the surfaces look great, leave the manifolds alone or check them too? I assume the flappers in the y pipe are a one way to keep water from coming back in the the risers? What am I looking for there Bondo? Thanks for all the help guys!
Ayuh,.....
What goes Bad is the Gasket Surfaces,......On Freshwater motors anyways....
If the Gasket Surfaces can be Cleaned up,+ look like the 1 posted by Tom,.....
Throw a New Gasket on it,+ bolt it back together......
And,......
Ayuh,.. The Flappers are pinned into the top of the Y-pipe on your boat.....
If they're in good shape,... No Problem.....
If they're Burnt Up,..... Replace'm.....
rad1026
Nice, I'll do it. Thanks everyone! Have a great weekend, I'm heading home to a nice bottle of single malt scotch.
Don S
And if the manifolds and risers all look good, get the OEM gaskets, not the aftermarket cardboard look alikes.
Here is the service bulletin on them.
Service Bulletin 99-10
