Installing motors,What is the biggest mistake people do?
2boats@hm
I am getting ready to install three motors into two different boats. (when it get warmer)Whats is the most common overlooked mistake people do that bites them in the butt later on?
thanks.:D
tommays
Re: Installing motors,What is the biggest mistake people do?
Trying to mix up the years were there changes with the 12" to 14" flywheel and one and two piece rear main seals
Tommays
erikgreen
If they're new motors or reman, starting them up without proper pre-lubrication.
Or, starting them without proper cooling flow to the muffs.
whywhyzed
Banned
Dakota47
putting a car motor in a boat.
mkast
Not following the Mercruiser maintenance manual.
mercrewser
Not installing a quick drain tube to the oil pan.
JustJason
remote oil filters are a nice touch...
Don S
Biggest mistake?
Not having a clue about the WHAT's , the WHY's , and the HOW's of what makes a marine engine and drive system work, and what each part does and why it does it.
rodbolt
mostly, simple failure of the installer to actually have a clue or the ability to read.
SuperNova
Attention to detail is critical. It's usually the small things that bite you in the keister. Not paying attention to the wear items that should be replaced while the engines are out.
Stan
