Help Needed
RabC
Hi there
My dad has a boat with a jonson ouboard on it and its doing weird things. When he starts it up there is a button he can press to put fuel through like a choke he says and that aint working and also when he turns the outboard off it keeps running. Anyone any ideas of what this could be?
Any help would be great
Clairex
HighTrim
Re: Help Needed
His kill circuit is not functioning.
First we need the year/hp or a model number.
RabC
Re: Help Needed
Ok great
il got the details from him 2moro and get back to u :D
Clairex
RabC
Re: Help Needed
Hi
The seriel number is J0003182 and the model number is 200649s
Clairex
Re: Help Needed
get year & hp, can't match #s. is it electric start or rope.
HighTrim
Re: Help Needed
It is a 1976 200 hp Evinrude
There is a faulty key switch, poor wiring, harness plug or the power pack(s) are to blame.
Look for a black wire with a yellow stripe. That is the kill wire. It goes from the "M" on the ignition switch, to the #6 terminal on both power packs. First thing that you need to do is check that this is still hooked up, and not frayed, or split.
That black/yellow wire must be connected to the "M" terminal on the ignition switch opposite the other "M" terminal that goes to ground. There will be 2 of them.
Did it just start doing this or has it done it since he got it?
HighTrim
Re: Help Needed
Regarding your second question, Im assuming that he has a toggle switch beneath the key switch on the remote control. That is the choke. Is this what you are referring to that is not functioning?
Re: Help Needed
switch wiring "http://continuouswave.com/whaler/reference/ignitionSwitch.html"
RabC
Re: Help Needed
Its an electric start.
When he puts the key in the ignition he should be able to push it in to prime the engine before he turns it to start but it wont prime. But if he turns it manually it will prime. Once its been started it is fine but its the initial start.
Any ideas?
Clairex
HighTrim
Re: Help Needed
Did he get the kill circuit figured out?
The normal operating position is to have that red lever positioned over top of the solenoid and aimed at the other end of the solenoid. Is this how he has it? Pumping the fuel primer bulb up until hard fills the carburetor float chambers, but that process also applies fuel pressure to the primer solenoid. Is this his starting procedure?
1. Pump the fuel bulb up until hard,
2. Crank engine and push the key in at the same time,
3. When the engine starts, release the key
ezeke
Re: Help Needed
First thing is to be sure of what you have.
The 1976 model number given is for an Evinrude 200.
It came with chokes, with choke plates.
The problems sound like the harness plug or the ignition switch.
It did not come with a push to choke ignition. It came with a toggle switch to choke.
HighTrim
Re: Help Needed
Exactly my thought as stated in my original posts. I have that exact motor, however in Johnson format.
Clairex, did your father just get this outboard?
RabC
Re: Help Needed
He got it last year
Its 150hp
Clairex
ezeke
Re: Help Needed
If the motor has traditional OMC wiring to the remote control, the attached link will lead you to specific wiring information that should help you. Please copy it to your browser without the quotation marks:
ezeke
Re: Help Needed
Probably the best electronics manual available is the CDI Electronics Troubleshooting Guide, which is available for free download at this link. It is worth saving to disk or printing, but it is large. Copy to your browser without the quotation marks:
CDI Electronics Troubleshooting Guide."http://www.cdielectronics.com/Downloads/tabid/55/language/en-US/Default.aspx"
RabC
Re: Help Needed
Hi guys
My dad says thanks very much its all sorted now :D.
The problem was there was no contact at the power packs so it wasnt sparking or something lol.
He has one more question tho:
Where does the wire for the rev counter connect to as it has been disconnected to?
Clairex
ezeke
Re: Help Needed
The tachometer needs three wires, four if you want the lights.
The positive and negative lines are purple and black, respectively, and come from the ignition switch.
The sender wire is grey and runs from the engine's terminal block, through the main wiring harness, and then to the tachometer. Depends on the control as to how it is wired at the helm, the sender wire is always grey, though.
Tell dad to be careful not to let any voltage run to the grey wire as it will destroy the rectifier or worse.
If he wants the lights, take a blue wire off the light switch or run it off the blue wire on one of the other gauges.
RabC
Re: Help Needed
Thanks
Il let him know when he gets in
Clairex
RabC
Re: Help Needed
Hiya
He says the wire has a grey outer coat but has an armour coating inside then a blue wire. Is this the right one?
Clairex
