putting mercruiser on engine stand
peacekeeper6
i have to rebuild my mercruiser and i pulled it out of the boat together can i just slap it on an engine stand then start taking it apart or do i have to take the manifolds and misc crap off first? Mercruiser 5.7 260HP
Don S
Re: putting mercruiser on engine stand
Depends on how good your engine stand is.
achris
More fish than mountain goat
If your engine stand will take the weight there is no reason not to put it on
peacekeeper6
one more noob questions but....where do i attach the 4 stand bolts? on a traditional chevy with a bare block i would do it near the water pump after i took it off. is this an ideal place for this motor also? How much does a fully dressed mercruiser 5.7 weigh?
Don S
NO-NO-NO-NO. That is not how you do it, even on a car engine.
Remove the engine bellhousing and coupler and bolt it to the bellhousing bolt locations. NEVER on the front of the engine.
I'll Post a picture of where to mount it when I find one.
peacekeeper6
eeek....i understand where to do it.
Don S
Assuming you are talking about an engine stand similar to the one pictured below,
Bolt the 4 support bolt to the holes on the back of the engine block circled in red in this picture.
96lt4c4
mounted on the rear
Flukinicehole
Wow are those cylinder walls polished? I dont see any cross hatch in them.
Mkos1980
Its advisable to also purchase a high quality stand with at least 4 casters. Dont need it flipping over ontop of your foot or even worse... you
jmoorepghpa
Buy or rent a quality engine stand. As a general rule I try and stay away from anything made in China/India/Pakistan etc. if that piece of equipment could compromise anyones safety when it fails.... needless to say damaging your valuable property. Do not buy a cheap engine stand. The quality control issues with imported goods are enormous and frankly appalling. I refuse to be the next guy on the news who got hurt or killed because of an inferior product. We hear constantly about lead paint in toys... what about guys who are hurt using defective imported tools/equipment? I would rather work the engine on a wooden cradle than put it on a poor quality stand. I'm not a union activist but I see a lot of guys buying unsafe garbage because "I'm only going to use it once".
