blueband 50hp, seized??
allymoss
Hello everyone.
I have just come into ownership of a 4cyl, mecury blueband 50hp with thunderbolt ignition. I have heard these are "bullet proof" motors but I have a problem.
Prop wont turn, cord won't pull. I have tried different gears but nothing happens. Prop is solid. As it won't turn in neutral, I am presuming the powerhead is not necessarily part of the problem but the gearbox might be.
Where shall I go from here? Shall I drop the lower unit? I have looked at it, and there are 2 visible nuts imbedded into the side under the flanges on the gearbox.
Only number I managed to get off the engine was on the side of the transom "1440-3255" any use?
I will post serial no. tomorrow as I can't find my torch and its dark! Shed lights are also broken! Thanks
Don S
Re: blueband 50hp, seized??
Pull the lower unit and see if the engine will turn over.
allymoss
thats what I was planning to do. I have been reading a bit and it seems reassembling the L/U is quite difficult!
Can someone tell me the fuel mix for this engine please.
HondaPower
Fuel-Oil mix for your motor is 50:1.
tmcalavy
Don't forget the nut under the trim tab/fin. Remove the fin and there's a bolt/nut lurking in there.
allymoss
Thanks for the fuel mix
I will be taking the L/U off tonight in about 8 hours and will post results here. Thanks
allymoss
serial no. is 2948379 Im presuming a 1979 motor due to last two figures....
I remove L/U that is stuck but so is the engine!! Im not sure the controls are working and would these prevent the engine from turning over if in gear as a safety precaution when starting? When I move the controls, nothing happens. I can feel the cable tense up but nothing engine end.
I have ordered a manual already but can anyone help me, advise what to do next. Thanks
Windykid
Does the prop turn now that the L/U is off???
Does the flywheel move??
Pull spark plugs and fill with penetrating oil, soak for a while and start working the engine.
allymoss
windykid, and I quote from my own post, "I remove L/U that is stuck"
and "but so is the engine!!"
I have removed plugs, they seem to be a type I have never seen before, flat as if normal plug has been sanded down and the arm has gone off and its just flat.
Anyway, what sort of oil, WD40? diesel I heard works well.
Nothing seems to move, gear lever on engine, flywheel, gearbox all frozen. I will try some force on the gearbox but not too much.
thanks
allymoss
Also, how to remove the lower cowling, made out of metal, ive removed all the bolts but I can't lift up off top because carbs and other stuf is in the way, cant pull down because transom is in the way!
allymoss
Right, I managed to free up the engine and gearbox BUT
DON'T KNOW HOW TO CHANGE GEAR!! There is a small shaft behind the drive shaft which turns a bit. I can get the prop shaft to turn forward and reverse a bit but not neutral. Can someone explain how this works please.
