Re: 1956? 12hp, Sea King
The pumps all have the same mounting pattern. The number I gave you was right out of the 1954-56 Gale parts book. However, OMC has changed the number probably close to a dozen times up through the years. Then along comes Sierra and changes some more. They will all work if they'll fit in the space. Yes, I prefer the larger Sierra because of it's better capacity. The pressure is the same. Better have too much capacity than too little. And you are correct, the carburetor determines how much fuel actually flows. Yes, I am certain that it is a Sea King. I just can't narrow it down to the exact year without the model number.
A Sierra/iboats 18-7043 carb kit will work just fine. As for lower unit parts, the water pumps should be the same for the models I quoted, but you will have to be careful if you get deeper into it. That is an area where changes may have been made, accounting for different model numbers.
Many, but not all, parts for your motor are the same as a '54 Evinrude 15hp.
Look on the side of the powerhead in the area where the fuel pump goes for a quarter-sized freeze plug with numbers stamped on it. Those will be the serial number and if you are lucky, also the model number.
I think you may be right about the pump. I actually thought of the same thing, but i wanted to be sure. their is plenty of room for the taller pump. Is it the same screw pattern, i mean will it match up to the hole, because the 7351 is for a 25hp i believe and do i need to worry about a higher fuel flow rate or is that relative. I guess it probably wouldnt matter, the carb is only going to except so much fuel, right? Incidently the PN # you mentioned didnt coralate. The # i found was a 304 sumpin sumpin. at this point im willing to just take a chance and purchase it to see. Based on the pics you saw are we sure its a Sea King, Im sure we would have mentioned that if it wasnt:redface: To throw another perverbeal (spelling) wrench in the wheel or (boat motor). what about lowerend gaskits and carb kit for this gem.
Again, I cant tell ya'll enough how great this is being able to do this online with you guys, your knowledge is unsurpassed.
Thanks, Pete
